Oh I'm sorry, I didn't know you processed claims and wrote PDSs for all insurance companies.
lol that's true.
maybe just car wont bother then, since the investigator clearly told me, the insurance doesn't care how much stamp duty i paid for it, that's the tax office's problem.
It would never be a factor.
Your car is either insured for market value or an agreed value.
What you put on a transfer form has no bearing as what you 'think' market value is, isn't market value anyway. Insurance companies go by official market values (which usually means they can pay you less than what your car is worth, if it's one of the better examples/modified etc), in which case you'd be a moron for not having an agreed value.
The son of an illegal immigrant asks his dad, "Dad, what's democracy?"
"Well, son, that's when Australians work and we get all the benefits from it!"
"But Dad, aren't the Australian people unhappy about that?"
"Sure they are son, but that's called 'racism.'"
think mine was market value cos it dropped a fair bit when i checked it this year (like 5-10k?) can remember lol
when's new wheels going on alex :P
Edited by UNR33L
According to an Indonesian judge vying for a spot in the Supreme court, it can be enjoyable for all ;)
Speaking of corrupt Asian countries, went to a night club in Kuala Lumpur. Came outside to see carpark full of lambos, ferraris, Amg's (and a r34 :P)
Dem kids with their corrupt family monies!
Nah I probably won't, I want to be able to take it out with ease, and be able to go back to a radio if I ever decided to.
Plus everytime apple decide to make an upgrade I will need to make a new facia. Fucc dat
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
