May be in if someone can pick me up. Not comfortable driving my car around after the slidey dilemnas on the freeway
Only read to this far, unless you've found a lift already I can pick ya up kunt.
Grad accountant who I extended the probation period for has spent 1/2 and hour trying to open a file but couldn't and is asking me why.
All she need to do was to unzip and extract the file
Say to her.... unzip THIS
They don't teach how to unzip files anymore?
And regretting extending her probation now?
Unzip this and extract semen? Will try next time
Training session is this month for her. So will see if there is an improvement.
20 years doesn't mean 20 years to develop a more powerful engine, there's more to it than that. Any manufacturer, even Daihatsu could put a 220kw N/A 2 litre engine in the thing if they really wanted to, but it means more money on production costs and less fuel efficiency. But try passing in the RB20DET under today's emission standards and you would be laughed at!
And for that matter, 20 years prior to the R32 GTS-T was the TA22 GT which weighed in at around 900kg and made 93kw from a 1.6 litre N/A engine...
I think you'll find this car to be positioned with similar performance to other sports cars within similar price ranges. They may also be making space for more powerful versions of the engine down the track, giving marketing something to keep pushing the product.
I was hoping to buy one as a daily but it doesnt seem worth the effort :(
I'll keep saving up for the BMW 1M :domokun:
Guest
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
