The false economy of stuff you buy and don't need is always gonna outweigh the savings on stuff you buy and do need.
That said, me and Aaron are on our way there now.
/southparkwalmartepisode
isn't 20% a little too much? 1 fish/12L is a very low stocking density.
especially when they're small
Not for African's.. they are extremely territorial and need more space
you can have it more densely populated but i think that looks shit
and 20% is fine for weekly... any less and my nitrates build up too much
you can go up to 50% if you need to
yeah, but I don't buy anything i dont need... I have restraint and brains
You fags living together now?
Seriously dude how many hobbies have you got? You are like the pretender lol
plants?
when i was doing predatory, i had an external tank that acted as a filter, with a section for plants. never had a problem with nitrates.
He reminds me of my ex-friend who goes to Asian countries and acts like a complete tool taking advantage of being a westerner over there and thinking he's king shit.
So like all the bogan Aussies who go to any Asian country? Made me ashamed saying I was Australian when i was in Vietnam.
Now understand why Australia has so many rules, it's to keep all the idiots under control. They go mental with no rules :/
lol i have tried to do as much enjoyable shit as possible with my 30 years
pro-am freestyle skier
pro dj
pro chef
skateboarder
fish dork
car nerd
and now banker/father
Guest
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
    • Sounds good. Provided the panel is flat/level I'd be happy to start the painting process.  While you are learning, for sure you could do this. Its only paint, you can always sand it all back and start again. Its only your time and money on materials, but while you're learning, really its time and money spent on your education.  Once you know how to do this bodywork and painting, you won't want to waste your time and money on frivolous activities lol.
    • Yep I will use a guide coat after putting filler, I will do it on the whole panel as I'm a beginner so chances I've made quite a few errors. In that photo, I think that was a low spot, I just for example said to pretend it's flat but I will put filler + guide coat after to assess where I'm at. Yep with that picture, the panel is wet as it rained when I took the photo. But all those scratches are completely smooth, I went over it with 240 grit and can't feel it, even with my nail digging into it. I was legit thinking to buy a 2k can and spray primer to see how it turns out but then thought to myself it's going to be a mess doing it haha. Good mention there. Thanks for all that info I think I know what to do next.
    • Prior to laying down the primer, you need to make sure the surface is completely level. For example, based on this picture, I strongly suspect that the areas marked in blue are higher then the area marked in green.  If you spray primer over this entire area, then paint and clear it, the finished result will 100% show the low area. It will stick out like dogs balls. Unfortunately the paint won't magically level out the low areas as you lay it down.  Without seeing it in person, I expect that the green area will need to be filled, then use a guide coat and check that the entire repair area is level with a large sanding block.  With this picture, are you saying that even though you can see the scratches, the panel is in fact completely smooth and flat? If this is the case sure you could prep and paint it as it is.     The picture with the paint you described as blistering, it's hard for me to comment on from the photo alone. It looks like the panel is wet? Dunno, looks strange. Does the panel feel as smooth as glass when you run your hand over it? **** Going back to your question again, generally you would only sand the primer if you made a mistake while laying down the primer.  If the panel is prepped properly and you lay the primer down properly, you should not need to sand the primer.  This wouldn't work - Don't prep the panel. Spray primer and see how it turns out. Sand the areas where the issues appear. Spray more primer and see how it turns out. Sand the areas....... Yeah you'd go round and round in circles getting no where.
    • That's sick, thanks for that, mine has much the same mods on a 400R. I just don't have the heat exchanger yet.   Might be worth a trip down the M1 to Syndey for a tune.
