can always spray them gloss black like I did, stands out less than normal
Yeh I should've done it when i had the front bar off, so ill take the bar off when I glassy light the headlights again, and spray it then
Yeah will have to put up with a Autobarn run..
(and not crappy parts autobarn..the fun one)
So I've done Good wood once b4 and it is insanely good.
and done the ring b4 as well which is hella fun.
the 24 hours is a little different, but not sure if I can could watch one race that long esp solo
but it is one of the few things left on my cars bucket list.
24 hour sounds boring as bat shit
+1
May as well go nuts in unrestricted Autobahn, racing these DB Bahn trains. I was mega jelly when I saw these BM's flying past while the train was busy being slow and backwards (no idea why).
TONY...
Car came with:
- Ground kit
- Front Mines 3point Strut bar
- Ralli-art rear strut bat
- Cusco front subframe thing
- Blistien coilovers (with cusco Camber Tops)
- Short Shifter
- HKS EVC
what i've done:
-X3e Front pipe 3"
-Xforce hi-flow cat 3"
- Apexi n1 evolution 3: cat back
- X3e LICP
- C\F lip extention's from John@rota
- White LED interior and numberplate lights
- Rubber Boot Matt (clark Rubber)
- Rolled Rear Guards
- Blitz Pod
- C/F Gear knob
- New battery
- Slotted rotora all round
- X3e Street Pads all round
- ASI Radiator
- E8MR BOV
- Walboro Fuel pump
- HKS Style front lip 2tone black white
- e9 Rear Bar
- SSR Sp1s limited edition 18x9.5+12
Update:
Upgraded to e9 turbo
Kando Dump Pipe
Kando Fitting Kit
FIC 1050cc Injectors
Silicone Intake
and had burnzy install and tune it all.
229kw on 22psi
He wants 21k with RWC - compression test was pretty decent (cant remember exactly but he has it on vid)
I offered him 18k as that was all I had... he didn't take it but has since messaged me asking if i still want it...
car is as is but without the professors
DOOOOOO EEEEEEEEEET!
princess hwy drags is my pick
i lol'd
Basing myself out if Stuttgart for a month
one of my best mates lives there and can show you around etc... tell me when you are going and i'll word him up
Guest
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
    • Don't assume the AC relay signal from the ECU is +, some models including Stagea use an earth trigger.
