true.. but for 18k it's a good buy without them... has everything done you'd want unless you have the need to go for 300 and then it's rebuild territory
just needs rims.... keep tyres and add black RPF01's brand new for $1500 and you have a killer evo for 20k on road
TONY...
Car came with:
- Ground kit
- Front Mines 3point Strut bar
- Ralli-art rear strut bat
- Cusco front subframe thing
- Blistien coilovers (with cusco Camber Tops)
- Short Shifter
- HKS EVC
what i've done:
-X3e Front pipe 3"
-Xforce hi-flow cat 3"
- Apexi n1 evolution 3: cat back
- X3e LICP
- C\F lip extention's from John@rota
- White LED interior and numberplate lights
- Rubber Boot Matt (clark Rubber)
- Rolled Rear Guards
- Blitz Pod
- C/F Gear knob
- New battery
- Slotted rotora all round
- X3e Street Pads all round
- ASI Radiator
- E8MR BOV
- Walboro Fuel pump
- HKS Style front lip 2tone black white
- e9 Rear Bar
- SSR Sp1s limited edition 18x9.5+12
Update:
Upgraded to e9 turbo
Kando Dump Pipe
Kando Fitting Kit
FIC 1050cc Injectors
Silicone Intake
and had burnzy install and tune it all.
229kw on 22psi
He wants 21k with RWC - compression test was pretty decent (cant remember exactly but he has it on vid)
I offered him 18k as that was all I had... he didn't take it but has since messaged me asking if i still want it...
car is as is but without the professors
DOOOOOO EEEEEEEEEET!
Tony, do it
TONY...
Car came with:
- Ground kit
- Short Shifter
- HKS EVC
what i've done:
-X3e Front pipe 3"
- X3e LICP
- Blitz Pod
- C/F Gear knob
- New battery
- ASI Radiator
- E8MR BOV
- Walboro Fuel pump
- e9 Rear Bar
Update:
Kando Dump Pipe
Kando Fitting Kit
Silicone Intake
229kw on 22psi
Tony, do it
I've seen that car irl and it's sick
Come on Toby
No Evo for me boys
Skyline4lyf
Was driving alongside a black evo on way to work. Was nice....
Join the 2ltr group. :P
lol I think you need to drive my Skyline and then not say that.
Really need a more daily daily. But not sure if Evo is right way to go about it.
By daily do you just mean 4 doors or less cop attention
I found my GTT to be a pretty good daily
2lt is not a problem at all birds...
given the gearing and diff ratio, my evo has basically the same amount of lag and almost the same length powerband my 33 had
feel free to drive it any time
4 doors, newer, more comfortable. But unsure about comfort factor...was riding in Aaron's the other day and I rate my Skyline for better comfort. I do like the cushy lounge style seats of the 90s.
Guest
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
