he would have man... but i am unaware
if you search "lams" on evolutionoz.net you will find a 10 page thread on it
cbf, need a full RWC just to view that forum.
Might peruse Carsales.
4 doors, newer, more comfortable. But unsure about comfort factor...was riding in Aaron's the other day and I rate my Skyline for better comfort. I do like the cushy lounge style seats of the 90s.
The front would be comfortable for your skinny ass
To be honest I find it pretty comfortable, but I'm coming from a small car extremely hard to get out of
2lt is not a problem at all birds...
given the gearing and diff ratio, my evo has basically the same amount of lag and almost the same length powerband my 33 had
feel free to drive it any time
You forgot to mention half the power lol
yeah, there's that too :/
i'd say that given drive ratio's and diff... evo's need slightly less power to be quicker in the lower gears..
i'd estimate evo 200 feels about the same as gtst 230...
not to mention that in the wet i have 700 times the power now lol
And if you're driving it on the street, lower gears is where its at... Who gives a flap how it pulls in 4th/5th/6th if you're not on the track...
exactly... but the way the 33 pulled from 150kph + I AM GOING TO MISS
I beg to differ, I wAs keeping up fine with the 240kw plus cars down the straight at sandown. It's a very under estimated car
Given above 150kph, is when they start to pull away
Even gave Scott a run for is money in the 350kw Stagea. He only pulled away at 120kph.
Hence why he bought one lol
I want to see this first hand. Not saying I don't believe you
Tonight
Your car vs say Simon/Birds
Roll on from say 70km/h. That's about the exit speed at Sandown onto the coming straight
from what aaron has said about this sandown trackday i'm beginning to think that semma didn't die that fateful day... he just got badly burned and decided to go into hiding as a srilankan collections worker
What? Who's semma
Tonight
Can be arranged. Although I have it on video with the go pro lol
Guest
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
