Dont worry brah... I have seen this situation before... you'll get it running again... even if you have to overnight parts from japan
But I don't have my car anymore.
Its sold to import monster lol
I'll jog your memory...
You were reported to have died on 1 May 1994, as a result of your car crashing into a concrete barrier while you were leading the 1994 San Marino Grand Prix at the Autodromo Enzo e Dino Ferrari in Italy.
as a result of your injuries and now crispy brown skin, you decided to hide away from all the attention as a young sri lankan man living in Australia... you adopted the name Aaron, because it was the first name in the book.
From here you continued to live undercover as a simple car enthusiast, however at one fateful sandown trackday, your raw talent simply could not be hidden!
Here you kept up with far more powerful cars including stagea's skylines, ferraris, radicals, zonda's, pagani's and mclarens.
It was at this point that I realised that I am extremely bored at work... and that YOU... MUST... BE... SENNA...
don't forget as I read on jalopnic this week
lost his virginity to a fat Prostitute at age 13..
Senna that is
I beg to differ, I wAs keeping up fine with the 240kw plus cars down the straight at sandown. It's a very under estimated car
Given above 150kph, is when they start to pull away
Even gave Scott a run for is money in the 350kw Stagea. He only pulled away at 120kph.
Hence why he bought one lol
I want to see this first hand. Not saying I don't believe you
Tonight
Your car vs say Simon/Birds
Roll on from say 70km/h. That's about the exit speed at Sandown onto the coming straight
pulled away at 120...so the start of the straight?
who doing 70 on the start there ,
I'm exiting the corner at around 100-110....
was painfull at rexmas,
got out of the corner great full power down the straight,
Chris Madden going past around 50-60 km/h faster...damn that 330kw...
you are different to other amatuer drivers martin
If you were talking about overtaking me on the straight, that's because I was trying my hardest not to let my engine lean out ;)
Really need to fix that...
Edit:
I wonder if that could have been the cause of the lower power figure on the last tune...
Assuming that a single dyno pull in 4th gear doesn't completely suck all the pressure out of the system but only drops it slowly towards the end... So the upper part of my rev range could have been running at say 80% of the fuel pressure it should be running at. If it was consistant, then that would have been included/accounted for in the tune right?
Pulling hard through 2nd / 3rd / 4th was leaning it to the point of misfire / detonation, so not a great feeling on the straight.
I THINK that the Walbro 255 is affected more by a lower voltage source than a stock pump or the bosch 040 that was in there beforehand... So if I wire up a direct feed to it with a relay coming off the ECU wire, it should pump more...
But will it also have a 100% speed whine all of the time instead of varying at Idle speeds? aka, stupidly loud?
I was more so talking about corner speed of that turn before the straight
Me?
Nah blue wrx, told me 230kw. If its false then that would explain it
My GTS-T is currently running it's 252kw safe tune...we can test this "Evo is the fastest car in the world" theory tonight...but I think I know the answer already. Short gearing means SFA in a rolling drag, unless you have a substantially higher redline than me and can carry the gear for longer...it just means I have to drop down a gear to be as short as you, comprende? You get the impression that 4th gear is fast going onto the freeway because it's probably the same ratio as 3rd in a Skyline...nothing Criss Angel about it.
On an unrelated note, there's a golf r that always fangs it past my work every day at about this time... God damn they sound sick on gear change with an exhaust, brrrrraaaaaaa CRACK brrraaaaaaaaaaaaa CRACK brrrrraaaa
That driver should be considerate and yell 'FORE!' before fanging it past your work.
How ironic that you would say that... Look what is across the road from my workplace...
Boss's Porsche Boxster has been hit a few times by stray balls...
https://maps.google.com/maps?q=-37.963638,145.033642&ll=-37.964763,145.032642&spn=0.009744,0.009645&num=1&t=h&z=17
Meh, its only a Boxster...
Guest
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
