25k for a gtt.. really? they pull that much?
nope they dont, there is one somewhere on carsales thats been on there for ages and he is asking like 40k for it just because it has a rebuilt motor all done in japan and shit like that.
thats what i thought kunce be trippin especially without the wheels and shit like :ermm:
was about to jack the price up on my 33 to 18.5 :laugh:
edit - mods dont make much difference mod money is dead money.
no shit, i'de rather have an engine built from aus any..
atleast when quering the build they can comprehend what your asking.
they just do. dunno why they are pretty cool to watch when theyre active.
yeh i had minimal water in there so the brine shrimp are closer to them when they want to feed..
and mum had the day off and thought the water evaporated so she put tap water in there.. i didnt see until the next morning they all died.. mum cried she was really upset..
another one is pregnant anyway so i may still have some when you get back.
cool.. i'll be getting a cat first then. =) and a japanese spitz.
Hey mate I have a rd28t gear box at mine just pulled it out of a donor car I wanna sell it would you be interested gear box is in good condition docent crunch. If you wanna contact me you can call me
DOCENT
I have getrag vt serice 1 97. V6. Do u. Have a gearbox? I cant find a rip shirfter to fit mine. So could i get a serice 2 vt getrag gearbox? And do you reco diffs? I have a spin restitant diff. I need it recoed and i want a truetrack centre? And do you tall sharft recos?
Cheers chris
Guest
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
