I was more so talking about corner speed of that turn before the straight
So the tight right left b4 the straight
I'm in top of 2nd so for me that just under 110 (have to cut corner a bit and use heaps of curb on exit)
as soon as I have straighted out of corner I'm into 3rd
then 4th just after the start line
then make a sandwich and check my hair due to lack of acceleration for rest of straight..
haha yeah it was ok, easy to make your's like that though or even better
I'll be more than happy with just that.. Would like to start when I come back from Fiji.
Keeping the car stock? Ain't no body got time for that!
Trying my hardest not to but not fun.
Haha mine was a 3rd-4th pull, so i did not to bad 230awkw against 280rwkw
Also tephra mods ftmfw
Still remember that night
That's me being passenger in the white 34R
Richos cnr speeds according to his videos on that cnr is about 80km/h though :/
It's cheap to get 230awkw, especially if you have full exhaust already
main thing is to get a 8mr or 9 turbo
Standard exhaust still lol. I'm just gonna buy all the shit I need and let it gather dust and do it all at once
Just make sure when you buy an exhaust, buy a good branded one, all the shit ones (front pipe especially) tend to fit really badly or not at all
also this was the catback I ran, sounded really nice and not to loud
http://www.ebay.com.au/itm/Apexi-N1-Evolution-Exhaust-for-EVO-7-8-CT9A-4G63-/380458896342?pt=AU_Car_Parts_Accessories&hash=item58951e0bd6&_uhb=1#ht_842wt_1397
yeah I get the feeling that I'm a little quicker though slower corners, lighter car and less lag due to set up.
high speed tho whole different matter.
if I keep the 7 turbo and do the LICP, x3e exhaust, 8MR bov, 3port and tune how close will i get to 230?
just trying to ascertain how much i'll gain from the spend on the turbo
also for the lICP is it just the hotside that needs doing or both?
Intradasting
You got a vid with data overlay?
Even billywhiz's s14 cnr speed is about 70km/h
New SL is gross, r230 shape ftw
Alex, pics of shoes please! where'd you get them?
Got em from matches which is in uk.. Half price ad free shipping win!
http://www.lyst.com/shoes/dolce-gabbana-velvet-loafers-black/
They reckon 220 with cams. 8mr is only like $350
Is the Time %age gap between you and richo a lot lower on tighter tracks? and higher speed tracks he just blows you away?
Like... Haunted Hills vs PI, lol
Guest
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
