i recon by the time i'm done the grand total will be pretty small
2'nd hand everything
turbo - $400
front/dump - $400
3port - $100
hotside LICP $100
already have fuel pump
Total $1000 + tune for 230awkw is pretty damn good
also $2000 total spend for 70-80kw gain (50% over stock) is hard to beat
20psi is stock
dat boost
Drove Aarons last night, sure as fuark doesn't feel like a stock car, dat pull in low gears <3
It's cause you are used to your cars gear ratios and spool rate. Jump in a diesel or v8 and you would have more pull in low gears too.
Birds explained it few pages back. It's no criss angel
true and untrue....
it doens't feel like a stock car, that's for sure
remember its an actual sports car from factory... has stiffer suspension, chassis is reinforced etc etc
but you are sure right about the gearing
turbo - $400
front/dump - $400
3port - $100
hotside LICP $100
20psi is stock
dat boost
Yeh pretty much add a catback to that and it's also my list, not hard to get there at all.
Ads $350 for a flash
But for a daily, feeling fast could be better than actually being fast and it feeling slow... Unless you want crazy butt raep fines.
On the freeway I pulled in 3rd from 70 (where I'd normally be in 2nd for a quicker spool) and I was quicker up until I ran out of fuel. Got got a little jump on me at the start obviously.
I only drove the evo for about a 1km of Springvale Road and didn't get over 100 80 kilometers per hour in accordance with state government regulation so didn't really get to feel the higher speed pull. I guess that's where the capacity makes a difference.
I also don't understand why it's got such a bad turning circle? Is it just that the wheels dont have enough lock?
Something to do with the 4wd system I don't know.
I wanted to do a 0-100 though.
Guest
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
