Ahh sorry about that, I wasn't involved in the process so don't know what's going on.
Sall good!
No worries wouldn't have been able to miss his 21st anyway lol
Oh hai there Moh
It'd look alright without those terrible wheels
At the front atm. Rears to come soon.
the aim is to have it functional since I plan on actually using the car.
and those who think rocking a sw sticker when a car ain't even fitted, you guys have nooooo idea
Edited by ARAB
really? seems like rockin a gtr badge on a gtsts, or a hsv sticker on a SS..
or oh wait, thats right its a 'family' yeh? lawl.
and to be fair the front isnt stanced, i mean you could put another wheel in that fender gap.
Edited by alr33x
Lol stancworks.
Does it stance work over big speed bumps or potholes? Lol
Nice one ham!
Andd my App Store is set to France apparently how the Fark do I change it back to aus? :/
You need to go Settings > iTunes & App Stores > Click on your Apple ID and login. Then you can change your Country to Aus. It will most likely already be Aus but just re-select it and continue through all the settings and confirm it.
Test fitted the 5 gallon air tank in the golf yesterday... it actually fits in the side panel behind the wheel-well, so I still have a useable boot and can put the trim over the tank and have it completely stealth! FUCK YES. Thinking of mounting the compresser behind the rear bumper behind the reo, so I don't get that annoying compressor noise in the car.
Guest
    • Well some mostly good news and some slight bad news.  Good news is cylinder 6 did in fact only require a honing and I'm good to run my 86.5mm pistons again. I should also get the block back by end of week. Bad news, had a few surprises pop up. First, main and rod bearings were trashed. No sign of any heat damage. I knew right away what caused this... I had not packed my oil pump originally and spent a lot more time than I would have liked cranking the motor to get oil pressure. It sounded fine once started so I chucked it up to luck and forgot about it. Luckily rod and crank are fine and just need new bearings. Engine builder agreed that this was the cause.    Another surprise that carbon covered up very well that I didn't catch, something got sucked up and went through cylinder 1, 2 and 3. Luckily this was no cause for concern, just needed a bit of cleaning up. Valves look fine but he will vacuum test the head this week to confirm. I'm presuming this was something left over from welding my intercooler piping, but we'll never know. I'm going to thoroughly reclean everything.    So all in all, happy the motor is fine, and I'll get it back much sooner than expected. I'll also be taking the time to convert my WMI system over to direct port. I'll snap some pictures of that when the parts come in.
    • I understand, thanks. Yeah I wouldn't want the car to tip over, I'll try and use the sills, I don't want to risk smashing the chassis rails. I ordered some rubber pucks that have a hopefully big enough slotting. If the front right gives me trouble I can always just make a wood block. I'll measure and inspect the sills closer once I actually take the car up. I hope so, but the rubber blocks I had in hand so far were pretty damn firm, if they are that hard they won't give much way. I'll let you know what happens. Angle grinding rubber isn't one of my favorite tasks. I'll probably start a build thread soon, for my own documentation and "log" as well as sharing what's going on with the car.
    • Kinda something I have been thinking about.  To be honest, we bought it already driving like that.  So there's no telling how long it actually has been driving like this.  Hopefully damage is too bad when we drop the pan.   I am having a hard time finding a site that sells the solenoid for the 5 speed auto, do you have any suggestions?
    • That'll be most likely down the road...  LOL
    • a stock / option or aftermarket?
