Need your opinion guys. Looking at installing a Walkinshaw bonnet vent on the SS-V but not entirely convinced yet.
I love the look of it but not sure how it'd look on my car. Main reason for getting the vent is I've noticed the amount of heat trapped under the bonnet is ridiculous, and apparently the ECU in the VE's retard timing like a mother when it gets overly hot.
Pic of my SS-V halfway down the page here:
http://www.skylinesaustralia.com/forums/topic/329280-victorian-post-your-ride-thread/page__st__1860
Pic of the Walkinshaw scoop I'm referring to here:
http://www.caradvice.com.au/wp-content/uploads/2011/04/FR4E7195-625x416.jpg
http://www.hp-f.com.au/wp-content/uploads/2011/07/powerhood_01_full.jpg
http://www.stationwagonforums.com/forums/gallery/files/4/2/7/1/26s.jpg
Yay or nay? Be a fag without a vent or be a fag with a vent?
http://www.skylinesa.../page__st__1860
http://www.caradvice...195-625x416.jpg
http://www.hp-f.com....ood_01_full.jpg
http://www.stationwa...4/2/7/1/26s.jpg
Nein.
And you should chuck a Vauxhall badge for lols.
fast and furious 6 hero car....
BenSopra kits look shit!
I was gonna say, do these bonnet bulges do anything or they just for looks.
Looks like they just stuck it on top of the bonnet.
Or are they whole replacement bonnets with the bulge and vents?
Hahahaha thanks for the input guys. I do like them but again, unconvinced that it'll actually look good. The vent is stuck on but does require the bonnet to be cut if it was to actually work (what I was wanting to do). Wouldn't install it if it wasn't going to function as a vent for heat extraction.
Anywhoo, thanks heaps for the thoughts guys, looks like I might skip the bonnet as it doesn't appear to be too many fans :)
NOT ROADWORTHY! YOU CUT YOUR BONNET!
oh its a commodore. youll be good. lawl!
Do it
Guest
    • Solid update, got all the downforces now.  You going to be running aus time attack again? love the jacking solution, spend the dollars on what makes it go fast is best way.
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
