Rb20 feels slow now. Hmm
cos it's stock phaggot
chuck on a bigger kando turbo, highflow the injectors, etc etc and raist the limit to 9000 (or even 9001 so technicnally it's over 9000) and drive it till it pops. get trent to tune it so it lasts a little while longer
you wanna replace it anyway... might as well have epic fun with it
you'll have a fkn ball untill then.
for reference, tim's micilour 32 was 260 rwkw and limited to 8500, and anyone that has seen him drive knows the true definition of abuse.
3 or 4 years now if i remember correctly
moh....
this is from the kando thread....
lol, if you want cheap and goodv i have a new kando td05h-18g...will make the power you are after and be pretty mega respoinsive. you just need to buy bthe exhaust housing fo $150 and you have a $600 brand new turbo to givev fabricator to mount gate on housinhg
dooooooooooooooooooooooooo eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeet
can we quit this faggotry about hub dyno's reading higher please? i'm soooo over it! they are better and more accurate... it's one dude in adelaide that bullshits his figures and happens to have a hub.
trent's dyno is callibrated correctly and runs the appropriate correction mode.
cars on trent's dyno make the same power as on a dyno dynamics in shoot 6 mode
my car was within 10kw of 2 different dyno dynamics rollers
easy...
F A G G O T
haha yeh true, my only experience has been like 10kw off racepace roller dyno, i know for sure that the SAU dyno day last year was reading way high though made over 30kw more on that stock than my stock run at my tuners, still always butthurt people complaining 'low dyno bro' I'll be back for my 400 :Dhttp://www.facebook....57935571022298/
on another note, f*kn massive headache this morning never again!(until next week)
Edited by UNR33L
yeah, I don't doubt that the chasers one is usually a little high... i've seen that a few times
lol yup!
not finished yet, so far it's just the cursive script in black on my inner arm.
next is a couple of blue and black swallows next to it
Sounds good, pics when done
Also get on it, cheap
http://www.catchoftheday.com.au/smallfish_info.php?event_id=2851
Guest
    • it takes so long to get things done but ... they are nearly there and we hitting the track soon again  So - at Perth Festival of Speed the car unfortunately had a decent off, wasnt me driving, wasnt the person drivings fault. Long story short car got sent very fast towards the wall without the control on throttle from the driver input and a disaster was averted but there was damage that needed to be fixed - carbon busted and alot of bent bits The splitter got munched and had to go back to get fixed - took a bit to get it there, fixed and back but got a surprise package when a new double element higher DF splitter came back - nice surprise !  and first person to have one     At a car show I took the car too some punks stole one of my carbon indicator blanks and stomped on the other so had to get a new set of headlight / indicator combo from tops stage so got front fender vents as well to put in the order     While all this was happening the new MCA golds turned up and did some fiddling around with those   Put in the flappy paddle system and clutch lockout wiring/ system   We have also put shorter gearing in top top it out at 300 kmph in 6th gear  where previously I held 5th to 282 at SMP and 277 in Perth   Looking for better control and faster acceleration     I wasnt intending on doing pedal box I was managing with the brake master replacement system I had going on and adjusted std pedals but on applying the clutch switch to the old system we found the *insert technical word here * bar that goes from the pedal to the master was bent about 40 deg and about to snap = lucky find otherwise be a bad bad time - discussion was had about getting a custom bar built to withstand the load but in reality it was time      making any suspension, wheel or anything adjustments to date has been a nightmare - aero off, adjust, check and repeat - time consuming and hard - short of going full airjack system we fashioned some external manual car lifts this will make life a million times easier     All the bent framing, some intercooler pipes and other has been fixed and replaced and after 6 months I finally have the car back at home in my control so its get to work on it, set ride heights, wheel align and will start track testing again soon   So ultimately other than a few flashy bits nothing actually looks likes its been done but in reality alot has. Typical   We'll see how all this goes
    • I'm far from an expert, but for sticking bits of metal together occasionally I got a MIG, the biggest one I could get with a 10a plug (because while I have some 15a GPOs around, they are not everywhere).  Also, because I get through SFA, I just buy the small disposable gas bottles at Bunnings, I'm not opening a BOC account to get through 1/10th of a full size bottle each year
    • FWD is different though.
    • Ignore the BOV / recirc valve question. You have an NA and shouldn't have one. If there magically is one though... It should be removed, though it shouldn't really effect it in the way one will for a turbo motor with it venting to atmosphere while running an afm.
