I've been known to remove my clothes for money, but I know a couple of the Gallery girls.
girls pay to see birds cock. seems legit.
ill describe her, she was cute as Fuark, brunette, no noobs and an amazing ass.
So...half of the girls there then...
Aqua?
In geelong atm for work myself.. not quite bondi.. still weather is nice at least, also whats with country (well geelong is half country i guess) girls being so dam fine, same thing at bendigo bitches everywhere
IDK bout that...
when I took grant to the hospital in shepparton after the DECA armco incident, the girls werent so much hot as 15 and pregnant
IDK bout that...
oh yeh forgot about shepp.. although still at the GV hotel there's usually a fair few.. the rippers however.. :\
Am I blind or crazy?
I thought I heard someone talking about 2013 DECA dates being released a while? Are they hanging around somewhere and I just can't find them or what?
Wanna get some annual leave cemented in for DECA Fridays
IDK bout that...
I was able to work out why everyone there is 15 and knocked up.
Shepparton North IGA, over the counter where te smokes are usually at, what did I see?
Boxes of condoms.
Boxes of condoms.
That's the problem... Condoms cost money... Centrelink only pays out Youth Allowance to 16-21yo, and the Dole to 21+ :P
15 yo's are screwed...
Point taken
The root of the problem, pub unintended, is a lack of sex education + fk all to do out in the country...so kids get a head start on life. People with young pregnant friends are also more likely to fall pregnant than those without, influence and peer pressure has a lot to do with it too. Too many factors really...
Guest
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
