Dirty 30 Toby, do it
Thought about it or put in a rb26 crank and go 2.7L but going to keep it simple and under budget
how exactly does one melt coilpacks anyway?
Not sure brah, would be curious to know what sort of plastic yellow jacket coilpacks are made from and what its respective melting point is
All I know is, if there was that much heat coming off the head that it melted the coil packs... I'd be looking for a new head :P
Valentines day is coming up.... Not sure why there is 8 of them, must be two spares...
you should contact the guy that bought my car and see if the motor / turbo setup is available.
he lives in bundaberg and has said that due to the floods he is not going to be buiilding a new car for the moment.
I have no idea if the car went under or not but i could ask i spose
i can give you the number if you want.
S1 R33 into a R34... ok.
it's a stagea motor...
so 26 block, 5.5lt alloy sump, 70,000km and was on an auto before my car.
Has rediculous compression and response = 18psi by 3200 with the 2835
well better than most stock 34 motors you might find
S'all good hambo!
I have a mate that will be doing my rebuild, so getting everything on the cheap cheap. Will just need to supply parts and let him do his magic
But i'll definately keep it in mind if everything is completed farked and I need to buy just a motor
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
