Went through two sets of Supercheap 3/8th no name brands sockets in a year when I first started playing with cars... Somehow was able to strip the insides of the sockets, even when using the correct size... and WITHOUT a breaker bar...
Then got a good set of Kingcrome 1/2" sockets ages ago and it's still in perfect nick.
Fark 3/8ths, I want to be able to work on a truck if I want to :P
I want a cool toolbox now... with rollers... and a built in fridge :(
hah i saw that the other day also! couldn't believe it....thought armin would of been in there and thought deadmau5 would of been higher tbh.. but seriously this wanker dj pauly d.. wtf, who would pay to see him..
The Situation here is that they have more tools than you Tony. :rolleyes:
Must get a set of those geared spanners i think they're called?
Wish I had like a grand to spend on tools...
Ratchet spanners are life savers
Links to a decent tool set that has everything? I might make a start to pull apart my engine whilst its sitting in my garage
I had some cheap tools that served me good for a while, but thief decided to help himself to my tool set.
I started with this set:
http://www.justtools.com.au/prod4348.htm
was a great base but added more to it since.
yeah I have a couple sets of those, so fkn handy for getting the job done
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
