Had oil pressure on the stangard GTR gauge at zero this morning..... shat pants.... farken around cutting down spanners to put mechanical gauge in at lunchtime. 50psi..... phew but obviously borked sender/gauge. GRRRRRR
In other news, anyone recommend any good 33 GTR's for sale at the moment?
Have a look at ash-s13 33r for sale atm, cheap cheap with good mods.
Was considering that car. Is a bit banged up, but mechanically looks ok
I was looking at that car last night.
not the best cosmetic, but makes up for it mechanically.
i need to get some decent tools sometime to be honest, took me like a week to replace my wing with a carbon n1 style one with my tools..
all I have is in this box
wirebrush and used ball of electrical tape comes in handy a fair bit
cottonbuds aint bad either
Edited by bluejeans
Go to Bunnings with $200. Get Stanley folding set. Never look back. Fits perfectly in the rear passenger footwell of a 33.
yeah i need to grab a set of something atleast..
might go have a look on the weekend
Guest
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
