Are there any other limitations, like exhaust etc, which you could rectify before the retune?
I havent changed anything, and car has pretty much (engine-wise) got all it needs. just need wanted Trent to do his thang on it, cause im not happy with the way it runs now.
Legs too muscular for skinny jeans :(
Lol, skinny jeans... Just no.
Been driving near the city to get to work lately... So many tards on bikes in skinny jeans, you can see the look of pain on their faces as they bust their nut, and not in a good way.
rolled Port Royale with a thick filter and using a $2 lighter that match my socks (which are visible from my rolled up desert-coloured Levis)... ooo yeah
now you're getting it!
I like to wear hoody jackets when it's raining and cold..... and i aren't no hipster!
I alway wear hoodies. How is it hipster. It's usually the thinner the clothes the more hipster you are. Hoodies are thick
Car club hipsters wear hoodies, not all hoody wearers are car club hipsters. Don't you bastards remmeber grade 3 Maths problems? You must have the other elements to complete the hipster equation.
Aaron is half way there with his iPad mini dash.
Sif half way there. I've been different since I was born.. My skins colour for example
And the iPad dash is a great idea admit it. Lol
different like the 20,868,999 other Sri Lankans on earth?
We are one, but we are many, and from all the lands on earth we come, we share a dream and sing with one voice, I am, you are, we are Sri Lankans
Guest
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
    • So I'm in the final stages of assembling my single turbo RB30/26 and had a question regarding MAP reference points.  I've seen several recommendations such as tapping the cylinder 2/3 ITB, tapping the intake manifold at cylinder 2/3, or using a point on IAC. First two are doable but require permanently modify part and the third is "out" as I plan to delete the IAC.  All that to say my question is can I used the "bleeder" in the center of the ballance tube as a MAP Reference? I'm running a catch can so I don't need it for the PCV system. My thought process is it "pulls" from all 6 cylinder, and it's between the ITB and the cylinders making it ideal for MAP reference according to what I can find. Thoughts?
