number 1 on the list just for Ham
http://jalopnik.com/...shole-123108858
lolfags
Bros...
Srs help needed. Have to choose the colour of the plates for teh Golfen-wagen by the end of today...
White on black like Rodney King...
Or Gold on Black like dat nga Jay-Z...
white on black as you ahve said you want to take them from car to car... duh
might have to raise the R.. :(
I think I need more camber in the front and cant get any without replacing the upper control arms.. but dont want to spend heaps on the Ikeya ones and the cusco ones say 'Skyline: Only 2WD Vehicles (GT-R Excluded)', not sure the whiteline kit will give me enough camber at the height im at also..
The upper arms are the same across the board. They're listed for R's as well.
http://www.rhdjapan....34-wgnc34-16650
Can see the only model variant not under the 1 part number is the N1 GTR.
Send Chris an email at Racepace, we have our own little set that we put on, can't tell you price unfortunately but I know they're competitive and some of the best you can get.
hrmm thats interesting!
wonder what rhdjapan are on about then..
I might do that, thanks mate!
I hope competitive with the cusco's and not the Ikeyas :P
is this what you looking for?
http://justjap.com/store/product.php?productid=17665&cat=&page=1
Anthony, Perfectrun have them cheaper than RHD
http://perfectrun.jp/src/detail.php?pid=35008&pname=FRONT%20NEGATIVE%20UPPER%20ARM&maker=CUSCO&maker_id=35&result_mode=pmk
$325 shipped
Or you can get them from Yahoo Japan for cheaper still.
http://page15.auctions.yahoo.co.jp/jp/auction/t287739855
Add 1k for Streeter/% for IM etc commission and whatever postage will end up being and they're still pretty cheap
I still don't get what its about after having it explained to me..
Seems to be the latest fad which will die away in a month or so
In other news:
Police shoot at hoons in Southeast
http://www.heraldsun...b-1226576662880
Haha cos shooting bullets at something that's at least 1.5 tonnes hurtling at you will stop it. Hope he aimed at the driver, cos shooting tyres at an oncoming car is almost impossible.
In other news:
What an idiot... Nothing to do with hoon behaviour though, it's about complete f'ing retard behaviour.
If the cop had time to draw his weapon and fire at the front of the vehicle, surely he'd have time to get out of the way instead?
I doubt he was TRYING to run over the cop, he was just trying to get him to move out of the way...
Mythbusters taught me this a while ago
Guest
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
