at least chatruese doesnt burn... pure alcohol? itd be like metho with delayed vomiting.
when in NZ a bartender offered me his 'under the counter' bottle of absinthe. said it was 85%. had a shot and 5 seconds later my stomach was like nup. walked to the toilet casually and vomited it all up.
http://gizmodo.com/5984476/meteorite-crashes-in-russia-panic-spreads
Fuarkkk
"What's more incredible: unconfirmed reports say that an air defense unit fired a missile as the meteor entered Russian airspace at supersonic speeds, shattering it to pieces."
Thats fkn mad. What happened if that shit happened to aus. Dont think we got no air defence units. Hahhaa.
f**ken just went to renew my passport as the old one full.
So frequent traveler passport with priority processing.
there goes $500 WTF
Bill it to work. If you can't afford passport, they can't send you overseas lol
company policy is that they don't refund passport
same as eg Aaron not refunded for drivers lic
am pushing for an exception tho
Lol so tell them you can only afford the standard rate. If they want priority they pay haha
http://gizmodo.com/5...a-panic-spreads
Fuarkkk
yeah i just watched all these videos of that.. pretty amazing!
didn't know they fired a missile at it! but I'm guessing there is no way a missile could of even caught it..
if it did.. wow.
lol in aus our air defense is just to throw other rocks at it
if it did.. wow.
Can't find a google image, but I am reminded of the Simpsons episode where the Australians throw cans of beer at the helicopter...and a throwing stick.
that throwing stick stunt of yours has boomeranged on us!
Guest
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
