One thing that I don't understand that is they advertise like they need a worker urgently and when I contact them, they suddenly decide that they don't need one urgently. Happened to me 4 times today.
What's up with that?
They also legally have to advertise the position, even if they had someone in their own staff that was gonna get the position regardless.
Mum just told me of it.
Annoying really.
That's not all jobs, government it is but private not always
You sure? That's what I learned in my Diploma of Management. Lots of private companies could get away with it though because it's not like the government is aware they need someone new.
If this is the case, may as well write the job ad as 'I've hired someone and I'm forced to write this useless ad just cause the law told me so'
How can private business be told by government they must advertise positions.
It's not uncommon to advertise and especially publicly listed companies for high end jobs etc but I'd be very surprised if its law. I do know government have to advertise from memory.
Despite anti-discrmination policies, I'd say most companies of a decent size have that rule to stamp out favoritism, and to at least have some chance of ensuring they get the best candidates - not just a mate of a mate.
That being said, 90% of jobs are transacted on the private market.
Applying for jobs in seek etc is like taking a Hail Mary shot from the back of the court. I remember one job I applied for I was one of 250 applicants. 5 round interview process and got to final 2....then other person got it.
If you want a job, consider your experience, skills and interests - then start approaching companies that lend themselves to those criteria. Call front reception, ask to speak to the person responsible for hiring. It will be hit and miss but it's a much faster way to the decision maker than applying for any and every job on seek with a generic cover letter.
No dont get me wrong. I didn't say don't use seek - im just saying there are other ways - you new to approach it from as many different angles as possible, an your best chance of standing out from the masses of applicants is to chose more obscure paths of application.
Good luck with your search - stay motivated, keep a routine and try not to procrastinate!
While we're here, don't write generic cover letters...target them for the company. It should be the applicant version of the job classified; a reply to it. Quickest way to get a discard is if they pick up on language that sounds like you haven't even read the job description!
That or you forget to take out the company name of the last job you applied for.....had one of those cross my desk recently. Needless to say he did not get a call back.
lol, the lazy and clever ones do a mail merge with company name tags throughout the letter!!! Still looks suss as fk.
Also agree re: targeting companies specifically. Consultancy and agency companies who specialise in your field and outsource / account manage for other organisations are always happy to take a look at new candidates.
Guest
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
