Just saw on ch9 news that an Indian was fine $100 for not wearing a helmet while riding his bicycle.
His excuse was that no helmet would fit over his turburn and that he can't remove the turburn as it's against his religion. Case is going to court.
Mum is literally LOL'ing.
he will win
I see plenty of people riding without helmets in front of cops, and they don't do anything lol
that has precicely nothing to do with anything
oh awesome!
should make him pay for all the damage!
Already got an insurance payout brah
What nationality was he? I've been looking for a race to hate.
Think he was European
Wow they actually pursued it. 10 points to vicpol..
Which leaves them at -84948262839494.88
Nor really pursued it, more of a coincidence of a related crume
Make him pay for your burnt coilpacks.
Glad they actually chased up the guy unlike mine..... did my own investigation and even gave them the link to the sale ad and fb of the guy that stole my car and nothing.... :closedeyes:
Did you do anything about it? Contact the seller and rock up?
Did they 'let some shots go' in his general direction hoping that it would stop him?
Nah he wasn't a hoon! So no shots let off!
i got stock r34 gtr AFM's if you want to try? Im guessing you would have upgraded though?
Have a z32 afm sitting around too if you running that?
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
