According to Wiki:
BMW M1
335 hp (250 kW) at 5900 rpm and 332 lb·ft (450 N·m) torque from 1500-4500 rpm (with +369 lb·ft (500 N·m) overboost). The redline is 7,000 rpm. Official 0-60 mph time is 4.7 seconds, quarter mile (~400 m) in 13.2 seconds.
Despite the car's larger size, it is 77 lb (35 kg) lighter, giving it a weight of 3,296 lb (1,495 kg).
370z
336 PS (247 kW; 331 hp)@7000, 365 N·m (269 lb·ft)@5200
Performance
The 0–60 mph acceleration times are as follows:
Nissan 370Z Coupe: 4.5 seconds
1/4 mile (coupe): 13.3 seconds at 105.7 mph
Curb weight 3,232 pounds (1,466 kg) (base)
I'm on my phone, did a search and someone painted the brakes on his lexus, would look sweet with the NISSAN lettering. If not, I can just throw some grey into the paint and have it slightly silvery
moh, instead of buying stupid shit like wheels, you might wanna sort out your suspension stuff first.
Going by the description of people on here.. sounds like Moh might have cut his springs to lower his car, a cheaper alternative to buying lowered stiff springs.
Change your rear springs moh lol
Nah his got coils. But his whole sussy system is f**ked. :P
Find it hard to believe that the 370Z would do 0-60mph in 4.5 seconds...unless it's got a trick auto transmission and diff setup like the R35, the power to weight and torque to weight ratios aren't in favour of it IMO. The Beamer has a much nicer torque figure, I could see that breaking into the 4s.
Lol barbs I'm not that Lebo :P
Johno, no it doesn't lol!
If I don't get rid of it soonish I'll splurge in some camber arms, bushes etc. mate rekons it's a rear wheel bearing causing the arse to play around.
I find this very unlikely
just what i saw, cant remember which ep of top gear, but they all chose the 370z over the m1
said it was a better car overall and the price was the last straw in the decision
According to Wiki:
yeah not to sure on exact figures
but i know 370z ain't no slug
Guest
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
