hmm i see i see, i think its large.
i have a big beautiful head...
saw some entry level helmets online.
around the $300 mark.
but looks like better off getting this for the money?
http://raceline-racewear.com.au/pyrotect-sa2010-duckbill-full-face-helmet.html
Invest in a proper anti-fog and anti-glare shield and wipe with Rain-X before each race. The shields that come with helmets by default are usually rubbish. Even if you buy a cheap helmet, a good visor can make all the difference.
Or...
http://www.velo.com.au/itemdetailspage/31915
In any case, if all you're using it is for CAMS events, just get one that's Snell SA2010 certified from the US. they're a lot cheaper than the extortion money local mobs ask. It won't come with an AU cert sticker, but you only need one of those for road use. For example those Pyrotech and Bell helmets can be imported from the US for about $100 less. Make sure you don't get an SA2005 helmet, cos you can't use those after 2015. An SA2010 you can use till 2020.
http://www.velo.com.au/itemdetailspage/37116
because carbon fibre.
and will get you laid.
on and around the track.
That video was made so quickly that it was played at the reception centre, an they only started recording that morning.
Dedication at its best I was majorly impressed!
Yeah read the description of the video and was impressed with the dedication in a 30+ degrees day.
Guest
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
