Bunch of bullies. Beat you both in the twisties :P
Birds; not sure if I could beat golf gti's and R's :(
You under estimate the handling of the FG chassis with coilovers! actually handles pretty decent imo i'd be very surprised if you could loose me through the twisties :P NT05s are awesome tyres too!
Jamie any good pics from the weekend?
Edited by UNR33L
only coilovers? thats cute :P
Come back to me once you rockin bilsteins, swaybars, adjustable camber & adjustable castor!
plus my e-dick is bigger too
started the R up and the rev meter is going f**king crazy... flicks up and down and wont settle anywhere lol.
looks like the excuse i need for the 320km one to go in
Do it.
Nismo 320 > Stock 180
bitch please, aftermarket swaybars ain't gonna save ya :P
what tyres are you on anyways? all of that suspension work is irrelevant with sheit tyres!
Russman had the same setup as my car prior to his rb25 swap and he was running rings around worked gtr's :P
33 Tachs tend to do that, dry solder joints or something?
yeah i read something about dry joints
Do it.
yeah ima buy one tomorrow
perfectrun have them for like $584.75 which is pretty good.
Guest
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
