every cop in vic at street next to mine since friday all to get one dude who may or may not have been armed out of a fkn house who ends up killing himself anyway...
my god aus police are crap. bet over in the US they'd have him out in under 5 minutes dead or alive who gives a f**k you're putting the kunt in jail anyway
This, we need harsher penalties for criminals
Russman had the same setup as my car prior to his rb25 swap and he was running rings around worked gtr's :P
Russman can also drive
should have built a gokart track in dande...
166528_10151673717569546_1637419521_n.jp
this dude was parked next to me at autobarn once...
he got ultra butthurt when someone came up to me and said how much better my car looked than the lambo lolol
you should have just gone over and asked the guy to turn himself in rimon. all would have been over in seconds
Rimon was the reason he holed himself up in a house in the first place
Convertible? Well there goes all the streetcred this car ever had.
man, i see minimum 2 86's on the roads every day. Getting spammed hard.
I park next to a white FT86 (and a burgandy R33... anyone on here?) every day at Gardiner station. The more I look at it, the more I keep thinking it should've been the new Hyundai Tiburon.
They should have dropped a turbo in not the roof.
There's already enough clueless housewives driving 86's. convertible is going to top it off.
Guest
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
