csb bro Did he give his camry a boot?
We're you the skyrine that was driving behind me on springvale road when we were all heading home and I turned off a bit after Princes Hwy Saturday night?
yeah that was me. You turned off springy road. My friend lives on that street. I was going up to FTG road.
why u ask?
So Ex demo car 7K saving + 1 month earlier v New car
How much do they go for 2nd hand? Aren't ex-demo's generally thrashed? Correct me if Im wrong.
Also make sure the 'new car' price is the driveaway price, and does not have other hidden charges.
Do you have alot of time off work during the x-mas period and thats why you want it before then?
Not entirely sure on full price but they are around 70 new. Yeh I duno about ex demos that's why I'm asking for advice :P but I guess your right they have probably been thrashed.
No time off work until jan but yeh I just want one :P I think I'll just talk to a few dealers see what they say see if I can find a honest salesman if they exist
you put a brake line clamp on the soft line near the caliper to stop air get in/oil getting out, less of the system will need rebleeding when you reattach the calipers.
had a go at 1 of the rears top hose is a bolt bottom one there's nothing couldn't figure out how to pull it off so i gave up lol. will try again tomorrow...
haha yes I am winnar.. all you Westies/Northsiders = FAIL
Im using 10W40 Motul Turbolight in both cars atm and I think its burning off like a mutha :< GRR
as soon as I figure out htf to get the oil filter off the S15 (kjghgfhjgff!!).. I'm gonna change it.. again :<
I think the 8100 used to be better but then thats 0W40! Have been told at Nats that Turbolight is like water..
Agreed, Turbolight 10W40 was like water. Used to disappear on my SR20DET and RB25DET, both of which were healthy engines (the SR reasonably stressed and the RB babied but getting on in km's.) Wouldn't ever use it again. Both my SR and RB loved Penrite Semi Synthetic 15W60, both ran quieter, smoother, idled better, temps and pressures remained better. And you would drain basically what you put into it, no dissapearing acts here. I'd definitely use it again on a highly stressed or slightly older engine. Tried running the Cube on it, engines too young and tolerances are too good so it was far too heavy and consequently made the engine noisy and sluggish. It would also have trouble starting on a cold morning, splutter and carry on like a bitch. Switched to Penrite Synthetic 5W60 and it runs like a dream. Quiet, revs better, starts instantly.
Amazing how much a different oil effects the way a car runs. No harm in trying a different oil for a short period to see what works for you.
Edited by llama_au
how much oil would you go through in the sr out of curiosity?
why u ask?
Thought it was you but wasn't sure :D
Yeah talk to the dealers but don't get sucked in on the day. Some of the car dealers are pretty full on...
Tony, you an accountant? need some tax/claiming shit advice
Not just any Accountant, the best. Your welcome to come into my boardroom office, and we can sit around drinking bourbon liek a baws.
With Turbolight - if I ever left as long as 5,000km and didn't top it up between changes (think I only did that once) I lost nearly 2L. Considering that's more than half the SR's capacity that's terrible. And it never noticeably burnt it so yeah...needless to say I started checking the oil more and eventually decided the oil just didn't suit my car. My ex's SR S15 was exactly the same, though his seemed to disappear even quicker.
With Penrite you'd nearly drain as much as you put in.
As I mentioned my RB lost Turbolight as well (although not quite as much), but again, not suited to that engine. Tappets were very noisy running Turbolight.
Too many bad experiences with Turbolight in my corner.
Guest
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
