if I got done for that i'd put up an add for anyone that wants their written off yet still running car removed for free and go and rip a skids in a cop shop carpark.
problem solved lol
This. Do you know how hard it is to have my car stolen? I leave my car in the open because it's insured for 11, which is more than most 33s are going to get selling...no dice. It's like they know which cars are uninsured or low valued :/
My friend has a r33 gts which doesn't have a working window for 6 months. The window is left full open when he parks. Hasn't had anyone touch it lol.
Will be trading it in for $2k. Not sure if buy and flip? People buy 33 n/a's these days?
every cop in vic at street next to mine since friday all to get one dude who may or may not have been armed out of a fkn house who ends up killing himself anyway...
my god aus police are crap. bet over in the US they'd have him out in under 5 minutes dead or alive who gives a f**k you're putting the kunt in jail anyway
Then they get questioned about their handling of the situation because he's dead?
He was a serial rapist and psychopath from the very little I know about it all, they should've stormed the joint the second they knew he was in there alone and killed him on the spot. He threatened to burn the joint down? Give him a box of matches and barricade the doors shut. Job done
Guest
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
