Do any of you dodgy professional kents know any decent places in Melb to pick up a leather briefcase? Doesn't need to fit much more than a 13" macbook air, some documents, a ipad mini and some small things. Something slim.
Kinda like this, but in leather.
Everyone parks their shitheaps at the station. So they park the R33 at the station. Why? Because shitheap.
Hey BTW, the dude you gave me for RWC? Good guy VACC. Took his time but did RWC no hassles didn't even pick up on stuff I put there as bait for him to pick up on.
f**kin lies. In singapore the only people I've ever seen engage the reverse gear is foreigners. They can hardly drive well going forwards SIFFFF they can drive better backwards. She's a dirty scamming liar, give her the works. I bet she had her hazards on while doing the whole thing so she claims immunity from all wrongdoing. Yes, in Singapore apparently if you have hazards on you can do any-f**kin-thing and not be liable... not the law, but you try explaining that to them.
Slam brakes on a freeway? Hazards on.
Park in the middle of a roundabout? Hazards on.
Run over a kid on a bike? Hazards on.
You want a Blitz Sus Power filter. Best filtration system (that still flows similar amounts to a pod) on the market if you're limited to box:
http://justjap.com/store/product.php?productid=18674&cat=272&page=1
Thanks. Still rocking the 3A pod you hooked me up with
Guest
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
