Honestly don't understand how you're not a massive fat kent...
On the flip side... Who's up for a wasteland squires loft night, maybe a week night next week? Like Thursday or something...
I'm in for squires. with or without ash spittin on my steak.
Is he giving you mad discounts?
I'm in for checking it out either way. Want me some steak yo.
BTW funkymonkey/shan ... If that's you in dp I swear I may have seen you at some point at my work. And your name is one letter off mine in that ive an extra letter lawls which is what reminded me because u or that guy was like 'hey ur name is nearly same as mine' lols. Or could be some other curry named shan, who knows XD
Edited by kaitoukid
You can take your car overseas to travel and keep your original plates on it. Saw a BM motorbike a while back with German plates. It needs to be all in English characters though so places like Japan do special versions of their plates which replaces the prefecture etc with English initials.
dunno. more f**ks could not be given about discounts as long as we get good steak.
You bros should get some numbers together for Sunday too. I had to lock in a table ASAP so I only got 4. 7:30pm Sunday.
Uhhh... I do remember sayin that to some dude name Ishan I think... can't remember where. Ohhh I remember at IKEA Springroll.
Saw a beemer on the freeway with british plates... eh?
you can pay extra on around the world cruises to take your car. get to country, drive car around, get back on boat, and repeat.
Guest
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
