Also, got a tune last night....
My tune history has been as follows...
260rwkw
250rwkw
244rwkw
223rwkw
Timing up high is like 8 degrees :P Power FC is pulling out all the timing because the turbo is making super heated air... We think I've got a leaking Intake manifold gasket (the middle one) so the turbo is working so much harder than it needs to to make 18psi...
Then I'm hoping to return to that responsive 260/270rwkw goodness
Twice in one week... Both while I was parked and not even near the car.
Great.... Just... Great....
Edit: Aaron, your people need to learn how to drive...
LOL you're copping it bad man.
Curries? What they say? Hahah
She tried to blame it on me for parking where the Body Corporate doesn't like people to park... and then started screaming at me about Karma because I didn't apologise and accept blame for her reversing into me.
I don't actually think your genetics make you a bad driver... but well, you did spin your car right in front of me on turn two at Sandown... ifyouknowwhatimean...
Lmfao are you somehow trying to say that Aaron spun his AWD Evo 180 degrees going around turn two at Sandown raceway on a warm-up lap???
Too low, suspension travel, and h-pattern on gear knob
No fine or roady, and a month to clear. He was mirin my neat engine bay, I think that may have had something to do with it
State HWP it says, got done on Beaconsfield Pde
Pics of said tidy engine bay plz.
Anyone have exhaust manifold studs for rb20/rb25
Have a new set and a used set, need the new ones though.
Edit: Actually used ones are incomplete and a couple were snapped.
D22 navara turbo failure
cousin calls me around dinner saying his car broke down at mt disappointment.
drive there, he starts it, WHEEEEEEEEEEEEEEEEEMMMM white smoke
pull off the elbow bolted to the inlet.
met with this.
worst. turbo. failure. ever.
were worried it might have grenaded itself...
got it towed to a mechanic.
asked him to check every little bit of the engine
If the motor survives this, I'd be really amazed by it.
The amount of stories about ZD30 grenading is HUGE!
met with this.
That's a disappointing end to his day
YEEEEAAAAAAAAAHHHHHHHH
Scott and his deflating my tyres to 27psi warm.
Squirming tyres felt like water haha even Richo drove it and thought something was f**ked. And yep, 27psi did that
Since we are talking genetics.. I'm surprised you haven't been in more crashes...
What with not being able to see over the steering wheel..
:P
lmao we were ripping dissa jokes on the cb when he was in the tow truck.
all quiet from his end, and then all you hear is, SHUT THE f**k UP
Yeah i do lol
Yeah we used all your studs. Was still one short. Had to use a bolt :/
Fitted the apexi intercooler. So epic. No reo cutting, no front bar cutting. Mounting Brackets lined up with factory holes. Pipes slid into position with no f**king around.
Shame they stopped making intercooler kits.
However in the process had to lose my factory options. No more auto spoiler and lost a fog light :(
Guest
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
    • Ah, to clarify if the car has already been tuned and has been modified and you want to go from a oem cat to a 100 cell or decat or vice versa.Are you saying that the car doesn't need to be tuned after a cat change if it's already been tuned?
    • This has been covered a bazillion times but google wet boiling point vs dry. Motul is only good when it's fresh, once it absorbs moisture it gets pretty average very quickly. So as above, make sure you change it if you're going racing. I run the Endless brake fluid in mind, but only because a mate is a distributor and it's cheap. It's not quite as good as SRF but I'm running 380mm rotors on a Skyline so it's not like they get hot.
    • That's the thing, they still add it and it makes fuel cheaper, implying adding 10% of it drops the cost of 91 by what, 5c a liter? I remember when it was barely half the price of 98. Because you know, 85% of what is in the fuel is way cheaper than 91 fuel is by volume.
    • Auto electricians that do repairs on automotive AC systems can source service kits. I don't know where they actually source them. I do know that there is one available for the R34 comp that I would need it for. If you have to pay someone to dismantle, clean and do needed repairs and fit kit contents, then you'd probably end up spending a good fraction of the cost of a new one. I would not be paying for that, because I would be doing it myself. My mechanic (bro-in-law) will happily source what is needed. Back in the day (like in the 80s and 90s), rebuilding an AC compressor was the standard approach, same as for starter motors, alternators, etc, because new replacements were v. expensive. After the China manufacturing boom and the rise of the disposable approach to everything, people just started throwing broken/worn stuff away and not rebuilding things.
