Scott and his deflating my tyres to 27psi warm.
Squirming tyres felt like water haha even Richo drove it and thought something was f**ked. And yep, 27psi did that
Lol my first track day at sandown when it was wet found out later my tyres were 26psi
Yeah we used all your studs. Was still one short. Had to use a bolt :/
Fitted the apexi intercooler. So epic. No reo cutting, no front bar cutting. Mounting Brackets lined up with factory holes. Pipes slid into position with no f**king around.
Shame they stopped making intercooler kits.
However in the process had to lose my factory options. No more auto spoiler and lost a fog light :(
Good to hear! Now you can start winning races :D
Just got an offer for $1500 for the pink S14. might take it. Anyone else want a track use only S14 for moar than $1500? Needs a wheel bearing and manual conversion
My first question would of been - why is it pink
ex queen st car. nuff said. they had cut the numbers out to do some dodgy shit and they had this perfectly good pink car left behind. basically bought it to make a track car, but then it lived in the back of my garage for like 5 years cos of skyline, golf, 240z and a heap of other cars being more fun to do shit with. Now I need to get my garage space back and I need it gone.
Can't be regged... ever... cos it doesn't have a VIN, and it's pink because of some mohomolebos in Syd.
2 get da chix wet cuz
Same colour. even had similarly mohomo chrome wheels that I told em to keep. Mine's a Series 1 (one in the pic is is a series 2). Wouldn't be surprised if this was the car that they used the VIN numbers for. Goddamn dodgy f**ks.
Haha soon...
I hope there will be no surprises when Trent tunes it. Car is hunting pretty bad now. Might have to check over the injectors, turbo, intercooler install
but richo didn't crash it right?
Guest
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
