Thanks, shall PM you later when I've got access to computer.
Not easy getting job for major construction companies?
Also do you have to be member for union?
They tend to be more picky....The company I just landed a job with started with 100 applicants, probably narrowed down from more than that...Cut that 100 to 30 for interviews, then 8 out of those 30 got jobs. Considering I'm an adult apprentice (over 25) it was even harder for me given that out of the 8 being hired, only 1 would be an adult apprentice..
Don't HAVE to be a member of the union...I'll be signing up though. Wasn't a member at my previous job because they were a bunch of cocksuckers that did nothing, but the ETU is a decent union (according to all of my sparky mates) so I'm happy to join.
You'll probably be pressured to join, but at the end of the day it's up to you. They might treat you differently if you refuse to sign up as well...but would depend on the job/people you're working with obviously
Dezz, yeah being adult apprentice is tough (am nearly 25 myself), it comes all down to selling myself and talking them to pick me over pimply faced young lads.
About the unions... I'll worry about it later, gotta find out more. I've also been told building/construction type unions are way better than other type of union.
Thanks again.
We are raffling two $50 fuel cards for those who want to help out at DECA in a couple of Saturdays time thumbsup.gif
Basically should pay for your trip up there.
http://www.skylinesaustralia.com/forums/topic/382413-deca-officials/
Also bit of an update to the DECA layout
Sort of the same. Depends on where you work. But CA is alot harder than CPA.
Had alot of people at our firm come from CPA backgrounds, try the CA and then fail hard. Failure rate in CA is pretty high. And when someone fails at work they usually cry, because you've just wasted money and 1/2 a year studying your arse off outside a full time job for nothing...
ah fair go. Grats on the credz. Always hard to do more studies after uni :thumbsup:
My uni course cost me 40k lol
+1 Engineering aint cheap :(
whoh what the hell is that?!! haha. Dont like change!!!11
Looks fun, although no more 1st gear handbrakies at start of mini wang
Guest
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
