oh nice! yeah you would man! lucky :P
well the list ive got is ...
nismo cluster
nismo brake lines
nismo clutch line
nismo super coppermix twin plate clutch
moonface superlap tie rod ends
moonface superlap tie rods
cusco tension rods
cusco drag rods
cusco front arms
garrett -9s
hks actuators
apexi power fc & hand controller
hks extension kit
hks cam gears
dba 4000 T3 rear rotors
kudos 100k service kit
project mu b spec pads
ID1000's
nismo fuel pump
trust oil filter relocation kit
i think thats all ive purchased.. and i still need to get
rear + front swaybar links
rear d bushes
swap for nismo triple gauge cluster?
anigif_enhanced-buzz-2360-1363797451-11.
housemate, buckles another housemate's wheels.
i cant even laugh in his face. this is agony.
borrowed his car to move stuff and hit something???
I leand my ute out to mates all the time to move things, but only ones I trust if they Fk something they will do all they can to fix/replace/make it right.
more like, housemate L (ex housemate to be exact) went to adelaide, his new place doesn't have secure parking, so he left his car at ours while he's gone.
housemate J took L's car to go somewhere, claims a yaris cut him off causing him to swerve to avoid a collision, hits curb, buckles two wheels. L is coming back from adelaide tomorrow. he's shitting brix because he can't remove the two buckled wheels, none of my sockets fit the wheel nuts.
and can i be your mate? i occasionally need to move stuff. lol. i also has wagyu.
can't find the recommended castrol 5w-20 oil for my car anywhere.. have to order in a 20l drum (takes 8.5l), can't get oil filter made by ryco etc. either as they don't make them yet for this engine. FFFFFFFFFFFFFFFFF
Edited by UNR33L
Poker cruise. - Done
Strip a car. - Supposed to help mate, but...
Potentially get drunk. - Suffering bad hangover, can't even walk straight.
That is my weekend so far...
One place that could help you with it.
Not only they supply oil and filters, they do service like safety inspection check, a man to do your dirty job (and drive your car in respectable manner), a hoist, etc...
It's called local Ford Service centre :P
most people use the recommended 5w-20 castrol or 5w-20 amsoil, there's a pretty big discussion on oil for it but at the end of the day comes straight back to what FPV recommends
http://www.castrol.com/castrol/sectiongenericarticle.do?categoryId=8002086&contentId=7069672
apparently some people are experimenting with slightly thicker stuff for tuned cars but majority just the edge 5w-20
just ordered a 20l drum from repco
Ford charged me $450 last service so cbf with that lol probably just look over it and change oil anyway.
Edited by UNR33L
Ford charge $450?! Did they at least give you a hand job?
Yep, Mazda is worse - not only did the oil filter i picked up today for mums mazda 6 mps cost 22 f*kn dollars but few weeks back needed to get a new drive shaft for the front, cost over 1k.. told dad he should of looked around at wreckers or something instead..
tl;dr dealerships reem you
Edited by UNR33L
Guest
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
