why buy from coles for?
also pobably gound fine because fo the parts used :P
probably. well because sometimes i need mince at 2am, and no where else but coles is open.
i normally just get mince from glen waverly, its a nice coarse mince where you can still see the fat.
He is pretty nice. He's just a bit stupid.
And Alvin's a flamin mongrel
lol you'll be happy to know that the guinea cops are gone. i'm a little sad though, having to throw away all those cucumber and cabbage and pumpkin offcuts. the cops loved those.
someone on ford forums just made 471.4rwkw with a intercooler and e85 :D do want
that must have included injectors, lift pump, swirl pot and at least 1 x 044 at a minimum...
but f**k that's rediculous
Only issue i've ever heard of was when some fool had like <1lt in the tank left 400+ rwkw and fanged it around powercruise or something similar leaned out and yeah needed rebuild.
whilst it may be power to weight of a 365rwkw gtst you're forgetting torque :P but yeah awesome for basic 'stage one' mods more than enough power to smash a 10sec hell be close to 9s with that power + the auto.
best thing about it is it's undetectable by popo, intercooler allowed as it's only intake mod (not that you can see it + no need to change standard intake already sweet) ECU standard still as it's just been flashed, no way to tell about fuel pump or injectors only give away would be the smell of e85 if you went that path.
Edited by UNR33L
i am also now looking at some of the cotd stuff... damn you !
and i was just about to sleep too T__T
edit: okay avoided any temptation to buy anything... from cotd anyway luls. now for long awaited sleep time!! except for some reason my room is freaking boiling skjd;adjas
Edited by kaitoukid
Guest
    • Hard line it, you will be thankful later on, if you car had hicas, use that as your return.
    • Hydro lifters not bleed up could be the ticking noise
    • You know the worst thing about acquiring more space for me? I tend to acquire more things to fill the space...
    • Ended up spending a WHOLE day yesterday cleaning and rearranging my shed.  Due to the aforementioned disorder, my shed is as cluttered and confused as my brain. Again, because of said disorder,  at any one time there are 5 projects on the go at once and because they're still on the go I don't put everything away so I can "get straight back to it" which rarely happens.. So anyway,  I bought a couple of cheap 2mx2m all steel "pallet racks" to put in my back shed.  The idea is to then take pretty much everything out of the main shed that isn't car related. Most of the garden and building stuff is now booted out to the back shed and onto to the shelves where they belong! There's still more rearranging and reallocating to do and it's still a bit busy in there but it's a massive improvement on how it was previously. I've discovered floor space I forgot I had...  For those that have fully dismantled a car before will understand just how much space it takes up!  Particularly panels, bumpers, engine/trans, etc.  I've got stuff hanging on every available wall to get it up off the floor!  This is not exciting content for a blog but has certainly made the shed feel like a more work ready space now!
    • Updating results from our ATR43SS-1 turbo in T3 .63, OEM bolt dump pattern. Not a big number but pretty sweet for a stock Rb20det. Car's managed to pull 220rwkws at 20psi, perfect boost control internally gated with EBC and excellent mid top end power band as they usually skydive after 5.5K. Usual bolt on supporting mods and inlet plenum and factory location exhaust manifold. Pump 98 fuel was used (Ron 93).
