Aaron. We barely half way through. If u come now. Still tonnes of food!
And there is no guinnea cops now!!!!
Good wine hurr too.
We just doing stuff bit by bit.
i do.. and i cant, already in bed.
i fkn hate you both. if he had told me 15 minutes earlier i wouldve been there!!!
Pshhhhhhhhh. Not dedicated enough. LOL.
But the guinea cops are coming back tmr for good.
Leigh next time you dive into a pool, drunk or sober, put your hands out in front...better with broken wrists or hands than Christopher Reeves...never go full Reeves.
Hsv releasing supercharged v8 soon
LS9? Would be more power in stock form than Leigh's car modified lol
Would buy.
wagyu burger.
and hamish, need temp controller for sous vide, was thinking of building one, but serioulsy.
no you dont, all you need is a thermometer, a straw, zip tie freezeer bags, hot water and an esky ;)
I sous-vide almost all my red meat and a lot of other stuff at home, and I dont have a controller
Would buy.
Nah, would be less... even with the capability to have that much power they will provide a detuned engine that can handle any fuel that idiots put in it, and then increase the output by like 5kw with each new model
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
