no you dont, all you need is a thermometer, hot water and an esky ;)
sous-vide almost all my red meat and a lot of other stuff at home, and I dont have a controller
Nah, would be less... even with the capability to have that much power they will provide a detuned engine that can handle any fuel that idiots put in it, and then increase the output by like 5kw with each new model
What kind of temperatures do you need to keep it at? Could you use one of those home brew kits?
no you dont, all you need is a thermometer, a straw, zip tie freezeer bags, hot water and an esky ;)
I sous-vide almost all my red meat and a lot of other stuff at home, and I dont have a controller
http://www.carsguide.com.au/news-and-reviews/car-news/hsv_supercharged_v8_tipped_to_top_w427
I cook most meat at 58c as per MY digital thermometer, and it comes out perfect every time, although my thermometer is pretty mangled as I have dropped it in the sousvide bath about 10 times and into a pot of 175c oil whilst deepfrying...
I usually get my steak from the vic market, leave it in the fridge until dinner and then throw it straight in a HOT griddle pan for like 60 seconds on each side to get some caramelisation on there, then throw it into some ziplock bags, suck out all the air with a straw and lock quickly.
drop it into the esky with the bag jammed in by the lid to hold the meat near the top of the water. set a timer for 45 - 60 mins and go watch tv or cook the other dinner bits
come back an hour later and chuck the bag on the bench to cool a little. and let the protien strands relax
cut the meat against the grain and throw on the plate with whatever sauce and sides I have made.
100% perfect medium rare rump steak that is as tender as all hell... every time
even the 427 would have only been say 300-320rwkw TOPS
I dont think it will be beating leigh's 370rwkw in a hurry, and it will be the TOP model @ $100k +
these are only guesses ofcourse
Also rwkw != manufacturer stated fly kw...
427 cubic inches = 7.0L
Bitch plz I could make 320rwkw with a few little mods to my little 2.5L ;)
mmmm but jelly of dat torque and power band... Super charged dyno graphs are boring... may as well go look at a wall, it's almost as flat.
inb4 leigh invites me to prinny...
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
