Yah, but he didn't muck around when he came to collect it, did a compression test then quick look at body and handed the bank cheque over. Took a hour all up.
Aaron is boss now
See if you get moar attention from da ladies now haha
Boss, more like I'm gonna dress like a complete utter bum and play very loud Chinese music to confuse the f**k out of people to see what kind of reaction I get
my esky drops approx .5 - 1 deg per hour so not really...
you can sear afterwards, works the same, as you are not putting enough cold meat in to drop the temp of all that water.
I have done both ways, however sealing first works better for sous vide as the flavour of the searing penetrates the meat.
even in professional kitchens with propper vaccuum sealers and circulators I seal the meat first
point taken, would probably try it then, BUT, how big is the esky you're using and what brand? and some have terrible terrible heat sealing.
wasn't much you could do about it after wheels slipped :\
makes me not want to take mine on track again now
yeah whenever I see something like that makes you realize how easily they can step out and be uncontrollable sometimes...
what happens with car insurance and tracks anyway?
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
