A45 AMG confirmed @ $74, 900 for September. 6.9-7.1L/100km and the 0-100 dash in 4.6 seconds...
EDIT: The Japanese ad had me convinced anyway...
A-a-ron get me one pls.
Edited by kaitoukid
for the myriad of things you are having done it would be a LOT cheaper to go elsewhere....
im more after a place which can do everything at once - tune + 100k service + install parts
racepace did an awesome job last time i took it there and is much cheaper than another place ive been to a few times, also their previous quotes were pretty low from what i remember..
anywhere you would recommend?
SHEES! where dod you used to have it serviced? Nissan Australia? :P
GT hyper and the Trent to tune...
their quote for my engine conversion was HALF that of racepace... HALF... I have been going there religiously since
ahah i used to go to le mans automotive in templestowe
damn okay half would be a big difference!
might check them out :P
was originally going to see if trent could do the tune
ty
Edited by bluejeans
ask for lin and tell them hamish from SAU sent you.
its a dirtly little shop lol... but they take care of the cars and have done nothing but 100% perfect work on my car every time
Strangely enough, I find the dirty little shops always to be the best ones to go to, and the ones that take most care.
Scott's shed for example, there is shit everywhere. But wouldn't go to anyone else..
I called up Lin once, booked in my car to install the new gear... Injectors, AFM, ECU, Turbo, Fuel pump etc...
Price was good as well, the only problem that he was really bogged down with work in the time span that I needed it to be done, it was going to take 2 weeks to get it done.
So I ended up doing it myself at home over the same timespan, just working a few hours each night... Learnt heaps and somehow didn't screw anything up :D
Wouldn't suggest that route to install all your new fruit on the GTR though, would be very ambitious indeed. (But would save a bucketload for sure)
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
