i start work @ 4am so cant call in the mornings..
i can call at night, though i have a huge list of parts and a question about if i need to supply 10.5mm adapters to fit the 11mm ID1000's in the factory fuel rail.. so it would be more a call to say 'check the email i sent you!'
:P
:P
Fair enough, there's someone there till after 6 most days if that suits or just call and tell to 'check email' lol.
They have adapters i know that, they supplied and fitted id1000's in factory rail just a month ago for me.
do you recall how much the adapters cost you?!
ive got a quote from tuff car parts place saying $114 for the 6
Not sure man, I bought injectors of them and they fitted it all up. I didn't ask questions!! They did get me the cheapest price for injectors tho.
Found 1 actions to perform.
Found 149,239 files that did not require action.
Analyzed 1,443.4 files per second.
Avoided copying 1,282,454,182,007 bytes in 149,239 files.
Saved approximately 16:28:28:00 by not copying any files.
mate is selling his s2 R33, turbo manual...white, stock kit with s2 front lip...
165,000kms, probably one of the few that hasn't been thrashed much coz he's a bitch and just used it as a daily..
needs a ute for work so he wants it gone, $6500
So you're buying it?
Welcome back brah
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
