Search NPC on these forums, or read the drivetrain sections. Always recommended. Mine is organic and rated to 300rwkw. Softer than the cushion button Exedy I was running before.
orly that all? I heard that the Exedy HD Organic is capable of 350+
Also Hamish I don't think we do!
if you can handle a snappy clutch grab the HHHDBC, it's cheaper and holds a lot more power than the organic...
I treated mine like shit and when I blew the motor and we pulled it out after 12 months it was like new
and are you going to see 350?
Not for a long while, but 300 is easy so I'd like to at least be able to handle a bit more (bit more = thrash it more on lower power ;) )
Don't wanna spend too much, found a company selling Exedy HD Organic for $399 delivered out of the UK!
Yeah? They good are they?
Yeah Co-worker said he could probably get them cheaper through there.
Is this for a gtr? If so I had a Racepace organic in my old r32 gtr I'm sure I was told it was a modified exedy. This was years ago tho! I had 290rwkw handled it very well all round but was ordinary on launches. Most organic single plate clutches won't handle big launches too well on Gtr's other than that they're pretty good for street use.
You mean the standard Exedy HD clutch? No way...those things burn out with 200; be surprised if they even have the clamping pressure for 300. Trust me, the NPC is the softest pedal feel and most daily friendly clutch for 300...cause it's a bigger plate than standard...after that you'll be looking at heavy pedal and button clutches. So many converted from Exedy to NPC.
Yeah standard 32R, will be putting -7s on it eventually though. Am thinking either Organic HD Exedy or this NPC that Birds recommended.
uwot? We put them in a fair few GTRs and they're rated to 350+, I'm sure they start to slip at that point, but I don't think they're gonna have trouble with 200 considering stock power already is 200 :P but I'm definitely looking into NPC now as they're a good $2-300 cheaper for the same, if not better clutch.
You sure you're not talking about the HHHD Exedy? Cause the standard HD organic is supposed to be as god as the cushion button, i.e. SFA power handling, just harder launches than a standard clutch.
I got my exedy from these guys..
http://stores.ebay.com.au/NORTHERN-BRAKE-AND-CLUTCH
were cheapest in melb when I got mine.
I gave them call and they did cheaper than their ebay add as no postage or listing feeds, plus a free exedy hat!
direct from excedy... got mine (HHHDBC) reeeeeeal cheap
would have to assume racepace would have an account with them or could start one at least
who with and how can i get said bargain?
buy mustang profit.
had car for 10 years and the agreed value goes up not down even with no new mods.
oh and to answer question, shannons
Guest
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
