When i WOT from 1-2 or 3-4 the car misfires when changed into the higher gear for a moment and then takes off. Anyone have any ideas to what the issue could be? Is it a tuning issue? Or could it do with heat range of spark plugs?
Car pulls through the revs just misfires on start of new gear and clears up. Dont think its coilpacks as they would degrade higher in the rev range...
Cheers
Cheers
Time for new car.
f**k, had to stop reading that thread after page one. The jimmies...they were starting to rustle.
Haha
I have also been through this
Talking on the phone with gf for 3 hours. It's 1:00 AM
Me: Ok, I guess it's time for me to go to bed. It was great talking to you
Her: Why do you want to hang up?
Me: Well, it's 1:00 in the morning and I have work tomorrow.
Her: Do you just want to get rid of me?
Me: No, I've been talking to you for 3 hours
Her: Oh, is that too long for you to talk to your gf?
Me: No, I like talking to you
Her: Then why do you want to hang up now?
Me: Because I am tired and it's time to go to sleep
Her: I hate you sometimes
Me: Why?
Her: Because you don't really like me. You probably want to date someone else
Me: I just want to go to sleep. I'll call you on my way to work in the morning.
Her: YOU ARE JERK! Why can't you call me right when you get up?
Me: Well, I would prefer to get ready and call you while I am driving
Her: You don't care about me! Are you cheating on me?
Me: No! Why would I do that
Her: Because you are trying to get rid of me! You don't want to talk to me anymore!
Me: I'm tired. I need to sleep or I will be a zombie at work tomorrow
Her: Oh, what is more important? Me or your work!
Me: It isn't about that. I have to go to work in the morning and I need to do well
Her: If I was the most important thing in your life, you wouldn't care about your job!
Me: If I lose my job, then I won't be able to take you nice places anymore
Her: Fine, go ahead and hang up. I HATE YOU! BYE
lol add "By the way...I'm cheating on you...and it's all your fault." to the end of that conversation and you'll have the ultimate irrational female thought process. Irrational behaviour or logic like that often involves some sort of lying or cheating cover up. Where there's smoke, there's fire!
P.S. a similar one goes like this:
Boy: You hang up first
Girl: No, you hang up first
Boy: Alright! *hangs up*
Next conversation...
Girl: You hung up on me...don't you want to talk to me anymore?
Guest
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
