So I just entered single life, haven't been single in 4 and a half years....... What do?
sorry to hear bro :(
I know how that can be.. sucks.
when ive been in that situation i found friends helped and keeping busy
so? you aint friends no more..
man if a girl did that to me knowing full well im in love with her, i would make sure she would become the most jealous person alive..
its a double edged sword.
While she gets jealous. You become a different person. Not the person she knew.
I jnow that feel borci and dez :(
Just walk away bro.
Her loss.
I put up a fight, the first week I thought give her some space, that the fight was ridiculous. Second week I got a little tired, tried to talk to her and see her every day. Third week I started getting emotional, telling her how much I love her and how things will change, tried everything. Now I think it's just time to resign to the fact that what's happened has happened, maybe it will be the best for our relationship and it'll fix itself, but maybe it won't and I have to move on. It's very hard for me as I'm not a quitter and have never ever let anything go, I always had the power and now I've got nothing.
Yeah, keeping my distance for now, she still contacts me every second day with something thats annoying her about me.
Like we didn't go out a LOT when we were together, she never had any money (no job), and I wasn't willing to pay for things for her EVERY WEEK.
So I've been out 2-3 times in the past couple of weeks, and she got angry at me last night that, I never went out with her, but now that I'm single I'm going out all the time and that pisses her off.
That's not quitting mate, that's knowing that you tried to fix the relationship and it didn't work...and it wasn't your choice to end it. No regrets. The only person who can have regrets is the person who called it off.
And don't talk to her when she tries to contact you. That's her getting her fix of you. She wants her cake and eat it too? Fuck that. She either takes all of you or nothing I say...if she doesn't want that life anymore then don't give her any part of it. How is she supposed to miss you, and how are you supposed to move on, if you keep conversing like that.
this
Guest
    • Have you checked the foam over the years? No deterioration to the foam from e85 mixing in oil? (assuming you're on E85)
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
