Let me know if you guys are going Tuesday... Might come down, you two gurus can teach moi :P.
Weekends @ goodlife is 7pm... 'tis okay. However sometimes I am jelly of my mates @ 24/7 gymes.
I need a nice leg routine. Gimme pls? Leigh/Birds.
So I just got to squires loft. I booked for 7pm. The clowns I call friends are at best probably 30mins away. WHY IS NO ONE EVER PUNCTUAL? FFS
As I said I'm no expert but my leg workout at the moment consists of:
squats (preferably first off)
leg press
leg extensions
standing calf raises
hamstring curls
oh and I almost forgot to completely finish myself off sometimes I go on the stair machine thingy at the end for 10 minutes at a moderate pace, by then my legs are pretty buggered and hard to stand up / move around at work lol
Edited by UNR33L
You should download the p90x ab workout is pretty decent IMO goes for 15minutes pretty intense but can do at home as well.
I sort of stole some of those ab exercises from p90x and occasionally do them at gym, need to do them far more often though I just hate doing abs makes me feel sick lol
leg press
leg extensions
hamstring curls
I don't know about you and having more of an office job, but fuarrkk when I got back into the gym recently, 2 days after leg day I could barely even crouch I was dying hahaha
Leigh, do you have to look down at the stairs on the stairmaster? I try and look up at the tv but always end up nearly on my ass so I just keep my head down :(
LOL yes, especially because we have it in the dark corner of the gym so not even in my peripheral vision
I occasionally look up but don't wanna fall on my ass
Basically the guys in my department got sick of me complaining about my legs every time I got up off my chair lol
Guest
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
