Dude's still nuts representing himself IMO...gets a judge with a chip on his block about people representing themselves and he cops $50k in legal bills, say goodbye to your 7 cars, not just 3. And the amount of work he would have put in to put forward a case...system is set up to deter people like him. Gamble paid off though. Hopefully he's set a bit of a precedent for others to cite.
my gyme is 1-7, if that helps :P
i'm starting to look at bikes again, omg! i think my dad (who used to ride, mind you) would chuck a hissy fit. do not want to get kicked out... however do want bike...
would any of you brahs have a bike only - no car?
Nah would never have bike only it's just not practical and takes away the 'fun factor' I reckon riding in peak hour is pretty shitty / dangerous too.
My dad bitched for a while, then I just rocked up one day with a bike not much he could say after I already bought it, he used to ride road bikes as well so bit of a hypocrite
I wouldn't mind getting 3 bikes:
Sports for super fast times, motard for lols and wheelies, dirt for jumping / bush etc :D
Edited by UNR33L
well *if* i were to get a bike soon, it'd only be for a bit less than a year tbh, because then it'd be evo time! :D
riding in peak is one of the advantages of bikes though, surely. but then again, i've seen what some drivers do in peak... :/
haha same with my dad, but his excuse a bit more valid in that "that's all they could afford" back then in SL... haha. but strong consideration to just do it and rock up and be like "k... what of it" :P
what you mean legal...
you are this guy yeah?
operation_repo_froy_tercero_zps8c677ec9.
Legal loss recoveries.
I deal directly with our in house lawyer and help with claims as well as just remarket cars lol
The amount of work the lawyer herself does is fkn ridiculous.. Did a day course at Leo cussins or whatever it's called and wanted to kneck myself after.
Don't know how ric does it
only watching ouji out of those. seen accel world though, i liked it. assume you've seen SAO then?
haha yeah pretty tempted to watch the source material instead of waiting weekly for shingeki.
"The council said the vehicles were taking up a majority of the property's open space and therefore, the land should be declared a store, as opposed to a residential dwelling.
But for it to be a lawful store, Mr Hoe would need a permit, which could only be granted if he did not live at the site and the cars were kept in a building."
hyakka and nyaruko is really full on mindless fun. i'm currently reading SAO. lol translated of course.
lol dad had one too back in SL. Mum has a hand sized burn scar on her calf from the zorst when he dropped it on her when they were first seeing each other
Yeah I used to drop documents to lawyers In city offices all the time Aaron....they would be sitting in a room literally surrounded by piles of documents they had to read through...needle in a haystack type shit...craziness
Hasn't market value gone up on The 86..
does that mean if you bought it for 30k or whatever they are and insured it for market value you could actually profit ?
that's assuming its a write off, and not a repaired car that can't be sold.
Looked like new bonnet, new windscreen, new bar, new headlights, new foglights, new reo, new bar reinforcement, may have pierced condenser and radiator just depends how far it pushed back and would only be able to tell looking with bonnet up, also hard to tell if airbag went off but I would be assuming it did. Add it all up with new parts/labour etc chance it could be written off
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
