I thought the Gen-F was suppose to look like this:
http://motoring.ninemsn.com.au/cars/news/8648110/hsv-confirms-new-gen-f-muscle
just read the caption under the pictures
"A 'MOTOR' computer-generated Gen-F prediction"
I reckon it looks better too ...
boy did we read hsv's mind or what!
$100k and in the GTS only.
430 at the fly, so what? 350 odd rwkw... that's pretty fkn good for a stock car... but still less than a tuned FPV 5.0
Lol exactly right, FPV massively underate the power figure
HSV GTS
Price: $95,000 plus on-roads (approx)
Engine: Supercharged 6.2-litre V8
Power: 430kW and 740Nm
0 to 100km/h: Less than 4.5 seconds
Ford Falcon GT
Price: $70,790
Engine: Supercharged 5.0-litre V8
Power: 335kW and 570Nm
0 to 100km/h: 4.5 seconds
so you got the same speed from factory, now chuck 30k into the falcon?
Nah but srs tune a 5.0 and what you got 450+ kw at the engine anyway, and you can buy a new GS for half the price. Hell give me a GS and a F6 for 100k kthx lol
I rate the new commo the hsv isn't that great but the Calais the showed off looked the goods to me and finally has an interior it should
And dat power off the showroom floor appeals to people like me who don't have time or know how to tune skylines an shit
Can't compare Gts to gt falcon maybe a club sport but gts would compare more to a gte which is also the better part of 100k as the gts is more loaded with options and luxury the Gt falcon I sat in rivaled the interior of a festiva.
Edited by alr33x
Michael you wouldn't know the difference between the R33 and R34 complete engine gasket kit is would you?
I've ordered a complete gasket kit for my Neo engine via High Octane. they supplied a normal 25det kit ensuring me it would be a fit.
Already know the plenum gasket is different
Unsure exactly what the differences are as I can't read the Japanese and it's not copiable text so can't translate without individually going through and grabbing all the jap characters which takes forever but it looks like there's quite a few differences.
There's only 18 individual parts to the 33 kit and 29 pieces to the 34 one. Looks like with the 34 the Valve stem seals are different for intake & exhaust whereas they're all the same for the 33.
The 33 kit also comes in 4 different revisions depending on Build date but the 34 one covers all Neos.
Part # for the 34 kit is 10101-AA525
So I see!
Same as this one:
http://www.kudosmotorsports.com/catalog/nissan-complete-engine-gasket-kit-genuine-nissan-skyline-r34-25gtt-stagea-wgc34-rsv-rb25det-neo-p-1059.html
Anyway too late now, can't wait a month for another order, already got a complete r33 engine gasket kit.
Will make do with what I have lol
Edited by blah_blah
rear end looks like an aurion
Yeah, cause the artist impression (Red Car) looks so cheap and tacky...
HSV GTS
Ford Falcon GT
Price: $70,790
WTF?!
HSV keep enlarging the cubic inches but still can only run the same times as cars with less...
So I see!
Same as this one:
Argh, just went through all the sections and worked out what the differences are..
R33 RB25 Seal & Gasket Kit
Sec Number
102 11011K Water Temp Sensor?
110 12279 Rear Main Seal
110 11128A Sump Drain Washer
111 11044 Head Gasket
130 13042N Cam Seals
130 13207 Valve Stem Seal
111 13270 LH Rocker Cover
111 13270M RH Rocker Cover
140 14035P Intake Gasket Runners-Manifold
140 14035 Intake Gasket Head-Runners
163 16293M Throttle Body Gasket
140 14036M Exhaust manifold gasket
150 12279N Front Crank Seal
150 15066 Oil Pump Gasket
150 15053 Oil Pickup Seal
221 22100E O-Ring CAS
148 23785N AAC Valve Gasket
- 11121Z Liquid Gasket
R34 RB25 Seal & Gasket Kit
Sec Number
102 11011K ???
111 13270+A RH Rocker Cover
130 13207 Valve Stem Seals Intake
130 13207+A Valve Stem Seals Exhaust
140 14035 Intake Gasket Head - Runners
140 14040E Intake Gasket Runners - Manifold
140 16293M Throttle Body Gasket
144 14415 Turbo Gasket Manifold - Hotside
144 14445 Turbo Gasket Hotside - Dump
144 14460G Turbo Gasket Coldside - Inlet Tube
144 15188A Turbo Copper washers water return
144 15192G Turbo Copper Washers Oil Feed
144 15196 Turbo Gasket Oil Return
210 22630A Temp Sensor Gasket
144 14188AA ?? Something for the turbo
144 15188AC Turbo Copper Washers Water Feed
213 15239M Oil Cooler-Block Gasket
Not huge difference really, 34 Kit includes the entire turbo Seal kit as ell which explains why it's so many more pieces. You could always order the intake gaskets separately if they're different.
Sec Number
Sec Number
102 11011K ???
Lol my head hurts from looking at that
Thanks for that Michael!
Dat N/A ?
lol did a quick edit
Lol I had it neatly formatted but when I copied from notepad to Sau it messed it all up :(
Just quickly tried to put an order on the 10101-AA525 kit.
For a $100 can't go wrong. Everywhere else is $400+.
Amayama's last day today so will see if it goes through
Yep, I called the use of the LS9 :D
Was the obvious choice without building their own engine...
Which is good news, because the same engine appearing in the ZR1 Corvette has 476kw and 819nm (!!!) of torque. HSV pulling their usual detuning tricks methinks...
I reckon that acceleration time will be conservative...unless they have it hooked up to a shitty transmission...cause even 2 tonne luxo barges with 400kw+ are down to 4 seconds for 0-100. In any case, there is no replacement for displacement, so if you got the cash to burn it'll be a better starting point for tuning than the GTE.
inb4 Leigh loses to one on the street :P
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
