My bad, it's actually the LSA, which is similar to and based on the LS9...but made for the Camaro ZL1.
FWIW, from what I read, standard boost on the LS9 with 476kw is 10psi. Guessing LSA runs ~5-6psi.
Yep, I called the use of the LS9 :D
Was the obvious choice without building their own engine...
Which is good news, because the same engine appearing in the ZR1 Corvette has 476kw and 819nm (!!!) of torque. HSV pulling their usual detuning tricks methinks...
I reckon that acceleration time will be conservative...unless they have it hooked up to a shitty transmission...cause even 2 tonne luxo barges with 400kw+ are down to 4 seconds for 0-100. In any case, there is no replacement for displacement, so if you got the cash to burn it'll be a better starting point for tuning than the GTE.
inb4 Leigh loses to one on the street :P
Bring it on!! :P
Looks like it's intercooler and pulley time if that hapens!
Previous HSV autos have been sheit, and manuals are just slow for drags compared to a good auto.
Yea ZL1 has the same power as the HSV will have 580hp or whatevs
Get a real engine like the Mustang GT500 :P 440rwkw ftw!
LSA only has 1.9lt supercharger as well (same as mine) whereas the LS9 has 2.3lt supercharger, then you got the difference in heads cams etc. LS9 also has forged internals and LSA doesn't :P
Edited by UNR33L
see Aaron knows ;)
it was pretty bad, scratched up n shit..not something I could fix in an afternoon...but had a crack at it...
then after taking about 4 million photos I find out I need a new camera cause they are nearly all blurry... :rant:
I also advised him to invest in some black paint for them wheels... :P
#@ARTZ Are you located in the east side? Might need a polish/wax detail or whatever you want to call it as my paint is stuffed after a trip to Phillip Island.
Got these weird patches all over the car and can't wash it off for some reason...
yeah bud...in Frankston but can work anywhere...
also were you on GOR cruise?...I think i have photos of you on the freeway..
Probably oxidation
Guest
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
