yeah ARTZ, I was there. Were you with Scott on the cruise?
hmmmm..... oxidation, how to get rid of it?
yea that was me... :D
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=419386
this is you yeah!! ^^
OK so some-one educate me here.
Bought a new battery for Katies Mazda 3 today.
Went with a basic Champion HD.
as I was putting it in I noticed the little advertising tags on top, as you do.
they claim, their batteries increase your fuel economy by 2%.. now considering I did a basic lift both and the new one is heavier than the OEM one it cannot be due to less weight.
SO how the feck does a battery improve fuel economy by anything???
If you teach me how to use it :P
lol..
get this
http://shop.finalinspection.com.au/product_info.php/cPath/39/products_id/141
some of this
http://shop.finalinspection.com.au/product_info.php/cPath/27/products_id/133
watch some utube tutorials, find old car, (not yours) wash it, clay it and start buffing...after about 20 cars you should know what you are doing..
can I have a go now? .. :D
my assumption is that it's to do with drawing less power to charge it
I thought about that.
But as far as I'm aware alternators run at a set speed not variable as per current load? that said I could be be very wrong. and thus asking advise.
I just think it a bad marketing plot and suckering ppl in.
if people are being sucked in... then it's not bad marketing ;)
Sexy driver is all I can think of when looking at that photo.... ;)
Sounds like their bad marketing plot suckered you into buying it Martin. :P
By making you believe so.
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
