GTR Shafts don't fit in GTST hubs.
The Drive shafts on my car (A-LSD GTST) were 30mm splined 5 bolt shafts
The new Diff has 6 bolt half shafts, so I decided to use the GTR Shafts that I got with the diff, but then discovered that GTR Shafts have 32mm splines.
So I pinched the 32GTR Hubs from Matt Borci's 32R rolling shell and swapped them into my knuckles...
Like a glove... ? Definite learning experience :P Now I just need to get my ABS working again and I'll be very happy :)
Whats the must have accessory for the gopro3? LCD screen or battery pack? Or neither.
what you want to use it for.
if your need long life the battery pack is good.
LCD is useless for the 3, just use the app and use your phone as view finder.
spend extra money on attachments and mounts and such.
LCD is a godsend for the GoPro 1.
never fit on the GoPro 1 HD2 had the expansion port, I've now got the wifi backpac for it and that better than the LCD as you can control it from in the car with it.
3 has it built in so even better
Happy birthday birds!
Fark celebrity apprentice hasn't started and yet I despise it already not to mention the lack of celebrities - dawn Fraser sure the rest have about as much profile as roadkill
i was thinking the same thing, at least the u.s version is alright.
I have the HD hero and it fits; pretty sure it's a GoPro 1
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
