I have the HD hero and it fits; pretty sure it's a GoPro 1
ok looked it up
so the first of the gopro as we know it was acautlly the gopro Hero 5, SD ran on AAA batteries and 2gig card only,
This was my first one so guess that why I call it the first gen,
then the Hero 960 a higher res version
then they dropped the numbers and started calling them.
HeroHD,
HeroHD2
HeroHD3
go figure.
My R33 GTRST made it to work this morning :D It's around the corner getting an alignment as we speak.
Now, who can remember the Bedding in instructions for a newly rebuilt 1.5way with Nismo discs... Hamish?
I need to go and do 30 minutes of slow figure 8's in an empty carpark somewhere that police aren't going to show up and defect me for "doing hektic skids"... This will flatten and bed in the plates in the lsd center by moving/grinding them back and forth against each other.
Keep speeds down (like try to stay under 60 or so) for the next 1000km? This one is going to be tricky since its a daily (but I can take mainly 60 zones to get to work and back)
Not bad job...
Pretty happy. Roof bonnet boot was all white and faded from oxidation.
Yet to see car in sunlight
nice...that red always does that...its a shocker...but gives good results when polished up :thumbsup:
so what machine did you buy ?
This is the car that killed my buff the other day...time for a new one...
<br />nice...that red always does that...its a shocker...but gives good results when polished up :thumbsup:<br />so what machine did you buy ?<br /><br />This is the car that killed my buff the other day...time for a new one...<br />
Bought das6 pro. Man this shit takes a lot longer than a rotary. At work I could have finished this car in 3 hours. <br /><br />Took 9 hours instead. But it was a single stage paint and layer was fairly thin. So I didnt want to take off too much paint. So no heavy cutter. Gave it a nice coat with 22ple as well. <br /><br />Whatd u do to the 300c? Like stage wise. Did it have a ceramic clear coat?<br />
Yep, this part I've got down pat...
What I'm wondering about is how crucial is the low speeds and how many km before I switch out the oil for the first time. Considering I'm using a "used" crown wheel, is the low speed stuff mainly to protect that if it was brand new?
Or would higher speeds affect the new LSD Center as well...
think of it like bedding in brakes... I did this for 30 mins straight away then binned the oil and used motul comp 75w150
Guest
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
